Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
Like Tree3Likes
Thread: OCZ Synapse Cache SATA 3 64GB SSD Review Discussion Thread
    I REALLY like this SSD!!!!
    Review posted here:
    OCZ Synapse Cache SATA 3 64GB SSD Review - Top Caching Solution At a Great Price - The SSD Review
    All Piks and Tests (some even unpublished) posted here:
    The SSD Review | Facebook
    Comments and opinions welcome and pass it around!
    Oh and congrats Hameister...Your published all over the world as of about ten minutes ago!
    Member Johnny Lucky is on a distinguished road Johnny Lucky's Avatar
    Tucson, Arizona
    Straight from the NVELO DATAPLEX web page:
    "Dataplex continuously monitors the way "you" are using "your" applications and data, and automatically keeps those files ready on the SSD for optimal performance. In a typical PC configuration, Dataplex delivers SSD-level performance by using as little as 32GB of SSD as a cache for your existing HDD. Finally, a single drive letter that delivers SSD performance, HDD capacity, and no data management or migration tasks for you! Simply plug and play!"
    NVELO also claims their DATAPLEX software works with any ssd and any hard disk drive. The software must be purchased through a vendor.
    I am not surprised that a SATA 3 6Gb/s ssd operates at or near SATA 3 levels - providing the cache contains the applications and files to be used.
    Super Moderator renosablast is on a distinguished road renosablast's Avatar
    Northern Ohio
    Les, would it stand to reason that a 7200 rpm HDD such as the WD1002FAEX ,1 TB, 64mb cache, SataIII would result in even faster performance than the 5400rpm Samsung 1TB used in your testing?
    AMD FX-8120 * Coolermaster GalaxyII S534 heatsink & fan * ASUS Sabertooth 990FX * 4X4GB Kingston HyperX DDR3/1600 SDRAM * 2 x Samsung 830 Series 128GB SSD (RAID0) * WD 1TB 7200 rpm HDD for backup * Fractal Design Arc Midi Midtower case * OCZ ModPro 600W modular power supply * MSI R6570/2GB DDR3 video card * 6 case fans with Scythe Kazemaster 6-channel fan controller * Windows7 Home Ultimate 64-bit
    Entirely possible and this was brought up by many in testing of the Revo Hybrid with its standard 5400RPM drive. The unfortunate part, however, is that the Dataplex software is tied to the drive once activated so I cannot change the drive now.
    Junior Member morphine is on a distinguished road
    May 2011
    Mississauga ON
    Quote Originally Posted by The SSD Guy View Post
    Thanks for the review! Looks like an interesting option.
    Just to clarify the statement above - if your mechanical drive fails you lose the licence for the Dataplex software?
    You would contact OCZ.
    Northern Ohio
    At that price point, I might just jump in and grab one. If I do I will post the before and after results.
    Junior Member spidertaker23 is on a distinguished road
    128gb or 64gb?
    Thank you so much for the review. I have been waiting for a review before picking on of these up. The only last question! Is it worth it to get a 128gb drive? or is 64gb sufficient? I have a 1tb hdd. Will the 128gb give better performance?
    Considering I pulled full performance from the 64GB version and they are over provisioned at 50%, I would be confident that this SSD will serve you well for some time. Think about it... It has 30GB of strictly caching! eheh
    I am kinda new to the idea of caching for a hdd. So the over provisioning is for what?
    So basically 128gb version would kinda be a waste/overkill? Would never really be utilized?
    If that's the case I will save the money and get the 64gb version! I just don't want to shortchange myself.
    Also my system is a SATA 2 system. AMD Phenom II x6 1100t - 8gb of ram. Do you think the 64gb version would be just fine?
    I am very excited to find out it improved your performance that much for boot times. That's one of the biggest things I wanted to improve on my system. I am contemplating caching because I have a 1tb WD black hdd that is almost 50% full. Also, it would be cool to improve the performance of my game load times as well as boot times and app loading (with boot ssd of 120gb I would only be able to boost speed of boot and apps - not games).
    Just trying to figure out if there would be any benefit to getting the more expensive 128gb version.
